FAST 92 intake
Old May 5, 2012 | 12:54 PM
Tyrel2018's Avatar
Default FAST 92 intake
i just got a 98 camaro ss with 99 injectors and 99 cam. it has tsp true duals and pacesetter long tube headers and a yank ss3600. i have a fast 92 that i bought awhile back because it was a deal. i want more power like everyone else but would that intake be too big for pretty much stock? i dont have a 92mm throttle body yet so i would still have to get one and i know that i would have to get a tune but im also worried about the injectors not being enough with that much air coming in. any input would be great because im getting a tune either way next week so i figure why not get it all tuned at once if im gunna put that intake on anyway. thanks Ty.
Old May 5, 2012 | 01:11 PM
Blu99T/A's Avatar
I would have put the intake on yesterday. Injectors should be fine with bolt on's.
Old May 5, 2012 | 08:19 PM
garygnu's Avatar
your current injectors will work.is seems when you approach the 420 hp level there is a need for better injectors.consider a mail order tune by frost ,it would alot cheaper.look at a cam swap and make that tuning worth while.
Old May 5, 2012 | 11:07 PM
Tyrel2018's Avatar
I have an ms3 cam also but I just done wanna take the motor apart right now I'm thinking about waiting till winter so I have something to do
Old May 5, 2012 | 11:55 PM
*02WS6TURK*'s Avatar
FAST 92 FTW. Love mine.
Old May 6, 2012 | 08:50 AM
black00ssFL's Avatar
Have you tuned the car for the injector swap yet? If not you're probably running dangerously lean as is. The '98's use 28lb injectors and '99's use 26lb injectors. Not a whole lot of difference, but enough to make you run fairly lean at WOT.
Get that fixed asap. Even though they are 26lber's, you should have enough injector for bolt ons.
Old May 6, 2012 | 09:11 AM
SweetS10V8's Avatar
This is very true, swap back to your stock injector immediatly if you havent copied and pasted all the injector tables in your tune. Then get the FAST on there, itll make a huge difference!
Old May 6, 2012 | 11:48 AM
Tyrel2018's Avatar
I don't have stock injectors to put back in that's why I have the 99s. I'm getting a street tune hopefully Wednesday.
Old May 6, 2012 | 11:59 AM
SweetS10V8's Avatar
Whoever is doing the tune, before they touch ANYTHING. Have them find a stock 99 tune and transfer all the injector data tables. If they cant or wont, dont let them touch your car.
Old May 6, 2012 | 12:13 PM
Tyrel2018's Avatar
Sweets10v8 thanks for the info on that. I don't know anything about tuning but I will deffinatly be calling the guy tomorrow and making sure he will do that first
