put headers on car wont run
Old May 5, 2012 | 10:47 PM
darrenrodgers's Avatar
Default put headers on car wont run
after installing the headers and high flow cats i turn the key it doesnt seem to want to fire right away gotta hold the key for a couple second i looked over all the coil packs, spark plugs, ground wire to the motor,starter wires,02 censors,alternator,battery,fuses.when i turn the key itll turn over and fire up for a second a die,i know im getting fuel and spark the exaust gets hot.Any ideas greatly appreciated
Old May 5, 2012 | 11:23 PM
Mumbles's Avatar
You seem to have covered the basics. Are you getting an SES light? If so, check the Codes. May give you a direction to look into.
Old May 6, 2012 | 08:14 AM
Tally TransAm's Avatar
coolant temp sensor
Old May 6, 2012 | 09:55 AM
Blu99T/A's Avatar
Originally Posted by Tally TransAm
coolant temp sensor
It is easy to break if it is aged and the plastic housing is brittle.
Old May 6, 2012 | 12:08 PM
thegroup's Avatar
Could also be the crank sensor if you knocked it off and didnt notice u did. That's been known to happen
