Help with FAST 92 Intake Install
Old May 8, 2012 | 12:38 PM
Tzone21's Avatar
Default Help with FAST 92 Intake Install
Ok so i bought this FAST 92 intake online with the buttonhead screws, ls6 crossover pipe kit and a fuel line adapter but after looking at everything i dont have the proper adapters to finish the install. Before i buy anything else i wanted to see what you guys think the best method to finish the install would be. Here are some pics
Heres the fuel rail that came on my stock ls1 intake
Heres the adaptor that fits on the stock ls1 fuel line
Heres the fuel line that came on my FAST 92 intake rail
Heres the bottom portion of the stock fuel lines
Heres the top portion of the line
What would be the best method for the install? Thanks
Old May 8, 2012 | 02:38 PM
dodson55's Avatar
do you still have you stock ls1 fuel rail that would be the easiert way to install it the fuel rails are the same.... someone has rigged the rail you have with a compression fitting you can cut the piece of line missing off an old fuel filter and compression fitting it to the rail you have and it will hook back up using the stock hose on the car but it will look like crap
Old May 8, 2012 | 07:45 PM
cranny's Avatar
Can't you just swap out the fuel rail with your stock fuel rail?
Old May 8, 2012 | 09:10 PM
KH504's Avatar
Start cleaning the heads first.
Old May 9, 2012 | 12:35 PM
Tzone21's Avatar
Thanks for the replies. Yeah it would be too much of a hassle to cut off that compression fitting without damaging the rail, so im just going to swap it.
