Differences between a 08 6.0l and a 04 6.0l??? Need help ASAP
Hi guys I recently bought a 6.0l from a yard, after further inspection I found the block to be cracked. So the guy said he has a few others one being from 08 truck. Now I believe the cam sensor is on the front of the motor correct? If so what would it take to make that work with my harness? Could I just switch timing covers? Thanks for the help guys
all engines 08 and up have the cam sensor in the timing cover and have a 58 tooth crank reluctor wheel in truck engines 07 came both ways gen3 and gen4 you can not just switch covers to use a newer engine you have to buy a converter box to use it and have to have a couple adapter harnesses you are better off just going back with a engine that has the rear cam sensor
