coolant temp sensor relocation?
Old May 11, 2012 | 12:25 AM
scj's Avatar
scj
Default coolant temp sensor relocation?
as many of you know there are two locations for the coolant tempature sensor to go on ls1 heads, one on the drivers side front of the head (stock) and a plug on the passengerside rear of the head. my question is, would moving the sensor to the rear passenger side head cause any issues with it reading correctly? i'd like to eliminate the wiring going complete over the motor to get to that sensor..
just for reference. the head on the right is the drivers side, the head on the left is the passenger side.
Old May 11, 2012 | 02:11 AM
bww3588's Avatar
Nope. Heads are interchangeable for side, coolant flows the same over there as it does on The drivers side...with the exception of vehicles that have the coolant plugs instead of the cross over under the intake. That area of the engine tends to run hotter. However, moving the cts over there, if it did get hotter would kick your fans on slightly sooner and possibly keep the engine cooler.
Old May 11, 2012 | 05:10 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I hate to butt in here, but what would you recommend to seal the threads with? Teflon tape, paste....?
Old May 11, 2012 | 05:27 AM
LS1MCSS's Avatar
A soft copper sealing washer would do more good, as the threads are straight cut. Teflon/sealers work good for pipe threads but don't do as much good on a straight thread.
