P0101 code problems
Old May 18, 2012 | 02:31 PM
randepandy's Avatar
Default P0101 code problems
I have a stock 2000 ss camaro and it is throwing a p0101 code. I posted this before but thought I'd start a new post. Car will start up fine for the first start-up but will spudder at idle until it eventually stalls unless i give it some gas. At times it seems as though when i step on the gas pedal it doent even sense it. I tried cleaning maf sensor and even replaced with a known working maf but still no luck. Any other suggestions cuz i wasnt really sure what else would cause the p0101 code?
Old May 18, 2012 | 02:34 PM
randepandy's Avatar
Oh and i did also unplug the maf to see if it would run any better and still no luck.
Old Jan 11, 2017 | 04:55 AM
Fight fit's Avatar
hi did you get the issue fix, i have the same issue
Old Jan 11, 2017 | 11:16 AM
You DO realize this is a 4-yr. old thread........
Old Jan 11, 2017 | 12:08 PM
Fight fit's Avatar
yes thats why i asked if he ever got it fixed!
Old Jan 11, 2017 | 12:35 PM
It's a long shot after this much time, but I hope you get your info! Have a good one!
