true duals... do i nees to cover the fuel lines???
So I plan on building a 3in true dual setup soon my question is do I need to cover the fuel lines and such with something? On the drivers side... Any help is greatly appreciates.
Lee
Lee
I just removed the lines from the clips and took the clips off. Then wrapped them with vacuum line and zip tied them to the mounting brackets. Use big ties and make sure they are not rubbing. I put one fuel line above the bracket and one below then the brake line in the middle. Kind of shadetree but so far so good. I have the tsp true duals.
Any of the local parts stores should have it. It looks like foil tape about 1.5 to 2 inches wide. you peel off the paper backing and wrap as needed. mine have been wrapped for about a year and my muffler practically touches the brake and fuel line and I have had no problems.
![](http://i939.photobucket.com/albums/ad236/b18kirby/heattape.jpg)
i remember a thread a while back where you can pop all the lines off the plastic clip, take the clip off and flip it upwards then hook the lines back on. it moves the lines upward about 2-3". i did this yesterday to mine and took about 10 min.
no i have not covered them. i guess i havent looked yet at just ho much room it gave me. u just have to remove the clips, and push them up. then re connect the clips to them. that simple. And as of 30 min. ago i do have true duals. just got the mufflers and x-pipe welded up.
