removing ac before tuning questions
Old May 27, 2012 | 02:55 PM
andy-lswon's Avatar
Default removing ac before tuning questions
I think I might have my ac removed before I get my car tuned. Will anything have to be changed with the belt system or can it just be removed. I've never did this kind of work before. I never use it anyway so will it be worth on keeping the car running cooler or squeezing out a couple extra ponies?
Old May 27, 2012 | 06:33 PM
NVR_SPDS's Avatar
Nope, assuming you have an LS1, the AC has a dedicated belt.
Take off the serpentine belt, and remove the AC belt.. Or you can just cut the AC belt. Pulling the AC cleans up a TON of room, and saves a good amount of weight in just the compressor alone.
Old May 28, 2012 | 03:46 AM
FourG63 97GST's Avatar
Pulling the a/c is more a weight saving mod IMO, the compressor disengages based on tps and rpm, so it turns into just another free spinning pulley when at wot.
Old May 28, 2012 | 08:12 AM
andy-lswon's Avatar
My cars not a dd and I don't use it when I do drive it so I figured it would save a little weight and help the car run cooler especially when I put the SSRA on there and a tranny cooler for a stall
Old May 28, 2012 | 10:57 AM
NVR_SPDS's Avatar
I actually dd mine with no ac. I also have a rather large trans cooler mounted where my condensor would have been.
Old May 28, 2012 | 01:45 PM
andy-lswon's Avatar
I never use the ac. Even with the ac gone I'm still gonna go with the ac version of the SSRA to make sure there's plenty of breathing room for the radiator and for a trans cooler when I get a stall
