Header Install. Heat shield on Driver motor mount.
Old May 27, 2012 | 05:29 PM
ebby69k's Avatar
Default Header Install. Heat shield on Driver motor mount.
I see there is a heat shield on the driver motor mount. I have BBK headers going in. Is this heat shield have to go back on. I don't see what it really does. Those stud bolts that hold the Drivers side clamshell to the block are a PITA. Thinking about getting some bolts like the Pass side. All in all big job but not to bad. Just time consuming.....
Old May 28, 2012 | 12:08 AM
99Bluz28's Avatar
I'd put it back on. The aluminum heat shield cuts down on the amount of heat that reaches the motor mount and the back of the alternator.
Old May 28, 2012 | 02:43 PM
sjsingle1's Avatar
i left mine off..............2 yrs and no pro...........
Old May 28, 2012 | 09:37 PM
therabidweasel's Avatar
I did poly mounts at the same time and couldn't get that shield to fit with the additional clamshell bolts there. If you are doing polys and you manage to get that shield back on please snap a pic. Those shields are there for a reason imo and headers are hotter than the manifolds.
Old May 28, 2012 | 09:39 PM
babbage1109's Avatar
I left almost all of my heatshields off. No issues to report a year later
Old May 28, 2012 | 11:10 PM
99Bluz28's Avatar
I reinstalled my shield, and I even did it with shorty headers still mounted to the heads. I don't recall doing anything special when I reinstalled the shield.
