question on double valve spring pressure
Old May 25, 2012 | 07:41 AM
redramair98's Avatar
Default question on double valve spring pressure
how many pounds of pressure is ok and not ok on a set of double valve springs?
Old May 25, 2012 | 07:52 AM
03Sssnake's Avatar
The spring mfr provides the specs for close and open pressures. If you are pulling one to test and its out of spec, time to replace.
Old May 25, 2012 | 08:42 PM
machine shop said it seams to high, i think it was 155 pounds of pressure, i called patriot they said thats fine, other places said 135 was max
Old May 26, 2012 | 08:56 PM
S10xGN's Avatar
You got aftermarket pushrods or stock?
Old May 26, 2012 | 09:35 PM
soundengineer's Avatar
As long as you have hardened pushrods.... You can go pretty far
It's not uncommon to see hardcore racers upwards of 800lbs open and 300 lbs closed with no issues...
The rocker and the lifters start to become the failing point..
Stock lifters start to collapse around pressures of near 500 open...stock rockers start to break around 600 ish
Throw in some good Morel lifters and an upgraded adjustable rocker and that issue goes away well past what most people will do
Old May 28, 2012 | 07:42 AM
i have a new set of ls7 lifters, stock rockers with the trunion upgrade, and trick flow pushrods
Old May 28, 2012 | 07:46 AM
TFS pushrods are just comp cams push rods with their name printed on them...so thats all fine and well
stock rockers with Trunion doesnt really change the breaking point, but you are less than the breaking point anyways
ls7 lifters are about the same as ls1 lifters.. they are still just stock lifters...
either way... you are still far less than the failure point from pressures.
Old May 28, 2012 | 11:08 AM
NVR_SPDS's Avatar
Just for reference, Im running stock rockers, with LS7 lifters (EPS 227/230) with my PRC EHT .675 duals. Closed spring pressure is 157@1.8" and open is 471@1.125".
Actually Im not even sure Comp makes their own pushrods. There is one company (cant remember the name) but they make a good amount of PRs for quite a few companies.
Old May 29, 2012 | 06:45 AM
so its looking like i should be fine then
