JB Weld On TB
Old May 28, 2012 | 09:33 AM
38DD2436's Avatar
Default JB Weld On TB
Anyone use JB weld to plug up the pcv and coolant tube holes? I want to remove them.
Old May 28, 2012 | 09:44 AM
Undertow74's Avatar
why? just use rubber vacuum plug caps
Old May 28, 2012 | 09:54 AM
dodson55's Avatar
why would you want to remove the pcv hose and you can just cut the coolant hoses off no need to plug them
Old May 28, 2012 | 10:59 AM
NVR_SPDS's Avatar
I just bypassed the coolant tubes, with a little piece of tubing. Left the connections on the TB open. Its just a straight-through tube so I would even worry about it.
With the PCV, just pick up a rubber vacuum cap, and call it a day.
Old May 28, 2012 | 11:14 AM
jimmyblue's Avatar
Moderator
I've done it. Prep is key, got to get the channels clean
and rough. I did the JB-Weld in two stages. First was
just a thin layer painted over the walls and foil dams
I made to keep the glue from traveling; second was for
the fill. Overnight 200F bake in between steps.
Now the coolent boss, I just cut off entirely with a
hacksaw to give more room for the bypass tube.
The PCV nipple can be removed easily, put a #2
Philips up it and twist it back & forth to draw it out.
Old May 29, 2012 | 03:11 PM
gMAG's Avatar
Use doctor-recommended JB Weld on dentures! Eat with confidence!!
