t 56 cant shift at wot
FWIW I ran the LS7 clutch and flywheel combo from Colorado Speed on my old 01 NBM Z/28 (bolt-on car), loved it. I am now running a Monster Stage II in the C5Z06 and Spec Stage III in the 99. If you are planning H/C/I or power adders down the road, you may consider a monster etc...
Now if i do have to take the tranny out would it be worth it to get the ls7 clutch for now instead of the monster stage II since i wont be getting a H/C/I for awhile prob next spring ?
When i get the tick's master, do i have to bleed out the old one first or just swap and im all set ? I'm hoping it wont fill up with black fluid again. If it does will it ruin the new one at all ?
Would bleeding it stop the black fluid or if it still shows up after bleeding means i need a new clutch ?
