Ls1 intake on Lq4?
Thanks.
The ls1 intake on the lq4 would just be taking a step backwards I think.
http://performancetrucks.net/forums/...d.php?t=397720
If you look at the data, basically LS1 intake equals the truck intakes so you really gain nothing! The LS6 flows little better than the truck one. But the LS2 90mm 4 bolt truck intake flows as well as the LS6 and it bolts in place of the 3bolt truck intake.
The truck guys quit the LS1/6 intake swap years ago as it wasn't worth the trouble for minimal gains.
You have to run a LS1 car WP with spacers or swap the pulleys. Then you have to relocate the idle pulley for TB clearance. As well as run the LS injector rails and injectors. Then you have to switch the injector plugs to the car style or buy pigtails as the connectors are different between the intakes for the injectors.
