Choosing Heads
Old Jun 17, 2012 | 03:56 PM
t56transam's Avatar
Default Choosing Heads
I am looking to buy some heads, I found a set for $1000 and I want to know if they are a good deal. The are ported patriot 243 59cc with comp cam double springs. Will these heads make good power and are they a good price? Also how should I go about choosing heads, I plan on going naturally aspirated.
Old Jun 17, 2012 | 06:29 PM
tremiles's Avatar
Are they new? If the heads are flat, the guides aren't worn, and the valves seats/valves are good that seems like a good price. With a tight combustion chamber like that, you're going to want some duration with your cam, and definitely check piston to valve clearance.
Old Jun 17, 2012 | 06:34 PM
baxsom's Avatar
also consider that they might need new springs too. for that much, I would spend 1200 and get TSP stage 2.5 5.3L heads new. dual springs, flow very well, and they will mill them to whatever chamber volume you want.
Old Jun 17, 2012 | 07:46 PM
t56transam's Avatar
They are used
They have about 3000 miles so I think the springs should be good. Do you know which is the TSP stage 2.5 will put down more power or not?
Old Jun 18, 2012 | 07:58 AM
garygnu's Avatar
if the heads are off the motor do a valve seat leak test.check all rocker bolt holes for any stripped threads.
