vented catch can
Old Jun 18, 2012 | 06:33 AM
superchargedgp's Avatar
Default vented catch can
so i have pcv blocked off (capped intake manifold, valley cover, throttle body and valve cover) I'm SD tuned and running a breather on each valve cover. the oil mist is getting all over my engine bay. Would running a vented catch can solve that problem. basically i would run dual vented catch can setup (one for each valve cover) take the breather off the valve cover, run a -10 hose to the catch can, and have it vent through it to catch the oil that is misting out of the breather
would that work?
Old Jun 18, 2012 | 12:09 PM
armyboyatc's Avatar
Why not run the PCV system? Its going to benefit you to run it. The oil mist thats getting everywhere is being pushed out by pressure in the crank case. The PCV system will help to relieve this pressure. I would still run a catch can but not a vented one. I would leave the system stock, run it to a catch can and then to the intake.
Old Jun 18, 2012 | 02:35 PM
because when i ran it with catch can i still got **** in my fast intake
