Voltage fluctuates at idle only after new alternator?
Before the new alternator i was having major discharging problems at idle and during driving. Since then I have rewired the battery, starter and alternator with 4 gauge wiring and gold connectors. Also bought a new battery and a new alternator. While on the street or freeway the voltages stays and doesn't move. But at idle the car will all the sudden just start to discharge into the yellow zone for a second or two and come back. It happens every 5-6 seconds. Anyone know what i should look for?
Originally Posted by wrencher
All the connections perfect?
Might have to get that alternator checked.
Have you taken a volt meter & confirmed that is what the voltage is doing ?
Voltage when car is off jumps from 12.5 to 11.8 randomly and while the car is on, just sits at 14.3...
LS1Tech Co-Founder
I don't understand this sentence "Voltage when car is off jumps from 12.5 to 11.8 randomly and while the car is on, just sits at 14.3..." you mean when the key is in the ON position it jumps around?
I autotapped a few cars a few years ago and I compared the voltages at idle, and most were fluctuating very little at idle. If you are seeing weird drops, big drops, something is wrong. Maybe your fans are kicking on and the fan ground is messed up?
Any easy things to check before the hard ones?
2001, alternator, cars, fluctuate, fluctuates, fluctuating, fluctuation, ls1, meter, rpm, trans, volt, voltage, volts, votage
