Cleaning the intake... got a couple q's
backfire. Then the 3M next.
Just full throttle start it & it wont flood.
Do not use the whole can & try to start it, do partial cleanings & then fire it up.
I say 1/4 can at the most at a time.
You'll never get it as clean as you could by removing it though.
Thanks,man.
I would clean it as much as possible, Just start it more often during cleaning.
Heck you can prolly just full throttle crank it over, let it hit & spin a sec & shut it down.
All with the thottle bore open no intake hose.
Just be prepared if it back fires out the intake.
Alot of repair shops do this same thing it's called decarbonizing.
