intake torque- do you?
Old Jun 24, 2012 | 01:31 PM
cartel's Avatar
Default intake torque- do you?
my torque wrench is foot lb-- wont be accurate at 90 inch lb..
havent done a LS or any plastic intakes before-- do you do them hand tight or does everyone go buy a inch/ torque wrench..
im looking for a new torq wrench anyway with the angle but was hoping to not buy 2 --
for inch lb i was thinking the 20-200inch snap on regular not techangle
Old Jun 24, 2012 | 01:34 PM
zracer323's Avatar
I picked up a cheap in-lb torque wrench from harbor freight. Cost me like $12.
Old Jun 24, 2012 | 02:57 PM
sheaadams86's Avatar
Just make sure u use correct torque pattern, make a snug pass then on next pass give it alittle bit more, if I remember right I think last torque is 96in lbs, which isn't much
Old Jun 24, 2012 | 02:59 PM
3rdCoastPowerSports's Avatar
don't use a ft/lbs torque wrench for in/lbs tasks... you WILL eventually strip something out doing that. torque is 89 INCH LBS. you can always use your best judgment when torquing to Inch/lbs but without a lot of experience doing this you are for sure to be off on your torque. seeing as its an intake and a vacuum leak from not torquing the bolts enough will be immediately noticeable and easy to fix im sure being close is good enough... but me, im of German descent its either 100% right on or its completely wrong and unacceptable
zracer323, The Ohio State University is the best University ever
Old Jun 24, 2012 | 03:08 PM
38DD2436's Avatar
^^ 100%
Old Jun 24, 2012 | 03:29 PM
2win_SS's Avatar
Here you go! All the info u need here. Torq specs and pattern http://www.ls1howto.com/index.php?article=5
Old Jun 24, 2012 | 08:26 PM
cartel's Avatar
i saw it was 90 in / lb thats why im looking for another torq wrench now
bidding on some 20-200in lb snap ons on ebay now
Old Jun 24, 2012 | 11:59 PM
2win_SS's Avatar
2 pass. Process. First 44 inch pound. 2nd 89 inch pound. Check the diagram for the pattern.
Old Jun 25, 2012 | 01:27 AM
itsslow98's Avatar
Just follow the pattern and snug them up. I wouldnt even bother buying a new wrench.
Old Jun 25, 2012 | 03:30 AM
01ssreda4's Avatar
I have an in/lb but don't use it. I do it by feel
