Pretty General problem...
Old Apr 18, 2004 | 07:44 AM
  #41
TX_SS's Avatar
have u ever had ur car tuned?? maybe plugs replaced??
Old Apr 18, 2004 | 11:38 AM
  #42
ThackerSS's Avatar
Plugs were replaced with the headers, and I just recently did the wires.
Car is untuned.
Old Apr 18, 2004 | 06:30 PM
  #43
CamTom12's Avatar
Originally Posted by ThackerSS
I ported my MAF, and painted it and my TB on the same day... I got some paint on the spring of my TB but I noticed driving around the next day it felt sluggish in the throttle... but I chalked it up to paint on the TB return cable.. making the difference.
I already have a stock MAF on its way, so I am going to throw it back on... the problem is I won't really know the difference until I can get back to the track though.
A copy of my Dyno sheet before the ported MAF and ported TB.. the car was making good power, tons of it under the curve... so with that power there I know my trap would have been a bit higher then 106.. I was thinking around 109-110. I'm afraid though that a ported MAF can't **** up my HP enough to kill 4-5 HP in the quarter mile though...
The dyno I went to did not have wideband.. so I couldn't tell you what my AF ratio was.
Just curious (I'm definately the lowest experience member posting here), did you get tuned after you put the ported MAF on? Is it a calibrated one or a self-port? I know that if it's not, it causes the motor to run rich (causing lower performance) because it's afraid to detonate. Does this seem like an on-track question, Ya'll?
Old Apr 18, 2004 | 11:07 PM
  #44
ZDOG's Avatar
well if you are using that much oil and its not on the ground, guess where its going! right through your throttle body most likely. i hear that can cause a fair amount of knock retard. i think we are getting warmer here! run a heavier weight 10w30 or (page him to check or do a search) patman is running 0w40(?) and is having luck with that. get a catch can! i need one too. good luck
Old Apr 19, 2004 | 01:25 AM
  #45
ThackerSS's Avatar
I just changed my oil today, used some 10w 30 castrol. The 5w30 mobil 1 syn like I said burned 2 quarts in 3k miles. Most of it was easy driving also... a trip to Panama city took up most of those miles.
  #46
ThackerSS's Avatar
Self ported MAF, untuned car. I went back to stock before the latest dyno though.
I am pretty sure the computer is just retarding timing instead of it being an actual mechanical problem, stupid Ls1 senstive PCM's.
Tuning is probaly my only hope.
