voltage drop
Old Jul 1, 2012 | 10:58 PM
victor111262's Avatar
Exclamation voltage drop
i need some help i have change the alt and the battery twice and still same problem.
the problem is that when i install the battery the volt would be at like 14 right well after a minute or two it drops to like 9 and it stays there i can turn the car on and off a **** load of times and it would still be at 9 volts, any ideas
Old Jul 1, 2012 | 11:23 PM
ls1fan00's Avatar
Are you going by what the dash gauge says or are you verifying the voltage with a multimeter?
i was chasing a similar problem for months on my car until i realized i didn't check with my meter. long story short my dash gauge is wrong and I'm at 13.9-14.4v all the time.
Old Jul 2, 2012 | 03:59 AM
Yea I guess I'm going by the dash I'm cheking it on the morning with the meter.
Old Jul 2, 2012 | 07:22 PM
NEXRACE's Avatar
I would believe the meter, its fast & a easy check. I have found those o'reily alts are junk in my opinion. Also if replacing, try to find the 145a truck alt. From what I read, they were on the subs & escalades.
Old Jul 2, 2012 | 07:57 PM
Jdsls1's Avatar
^^+1 145a truck alt. That's what I did. The car ones are junk and new ones can literally **** out in the first hour.
Old Jul 2, 2012 | 08:03 PM
djfury05's Avatar
Check all your grounds in the charging system
Old Jul 2, 2012 | 08:31 PM
I haven't been able to check it I been at work but tomorrow I'm off so I'm going to check it, and yea that's the alt I'm going with if this **** goes out a friend that works at sears got it from pepboys with his company account its supousibly the best one they had u forgot the amps do
Old Jul 5, 2012 | 08:36 PM
I just check.it with a meter and I'm getting 11.75 volts on battery and on the other side
Old Jul 5, 2012 | 08:43 PM
With the car on I get 12.2
