Fuel pressure for 42lb injectors
I just want to know why he said to run it on 43 lbs as opposed to the factory 58psi. is that how its supposed to be or just something that this tuner does.
What injectors do you have?
- your injector's flowrate is 42.29 lb/hr at 43.5 psi rail pressure;
- they will flow 42.29*sqrt(58/43.5) = 48.83 lb/hr at 58 psi;
- what rail pressure is your FPR set to...?
- is the rated flowrate measured with heptane or octane (what does the spec sheet say...?)...? if heptane, you will have to scale both of the above cases for octane (octane is denser; the injectors flow the same volume of either liquid, so flowing octane will flow more mass);
- if your FPR is vacuum referenced then the IFR table will be flat (same value in all cells); in this case measure the rail pressure with the FPR reference hose temporarily disconnected, and use this to calculate the IFR;
- if your FPR is unreferenced, the IFR table will be sloped (actually goes as squareroot), you will need the famous spreadsheet to calculate it; it this case measure rail pressure as is (unreferenced);
Your tuner should already know all that.
But in any case, make sure your tuner has gotten all the other injector tables filled out with the correct data for those injectors.
(with reference hose removed your rail pressure reads 50 psi, same as you said at WOT)
(the IFR table should have been calculated for 50 psi rail pressure; if it wasn't, then the tuned VE table will correct for it (i.e. the VE table is scaled to the IFR)).
since your FPR is manifold referenced, your IFR table should be flat.
