90mm LSX install complete...pics within
Old Apr 15, 2004 | 04:50 PM
Spellbound's Avatar
Originally Posted by Fireball
trim the angle some...other than that...they slid on with some persuasion
Thanx, I just ordered one.
Old Apr 19, 2004 | 06:06 AM
Fireball's Avatar
Update...
Looks like its worth ~2-3 tenths on a good H/C car. Typically was in the high 11.2 to 11.3 range in similar weather. Ran 11.08 with it this past weekend
it was still a tad rich...I'll lean it out some and retry soon
Old Apr 19, 2004 | 06:56 AM
Damian's Avatar
LSX Mechanic
Is the 85mm MAF a must to run the 90mm setup?
Old Apr 19, 2004 | 07:24 AM
Fireball's Avatar
why choke the 90mm setup with a 78 mm maf???
The LS1edit MAF tables I found on here for descreened Z06 mafs (with the calibration resistor cut out if bought from SLP or whatnot) were VERY close in tune
Old Apr 19, 2004 | 10:10 AM
BTL FED's Avatar
If you have edit here are all the values for the maf table of a screened and descreened 85mm Maf
http://www.c5howto.com/index.php?article=25
Old Apr 19, 2004 | 11:04 AM
Fireball's Avatar
Those were the ones I used
Old Apr 19, 2004 | 11:05 AM
Fireball's Avatar
I'm thinking of putting in a 3/8" barb to 1/8" NPT connector and threading it into the bellows with some RTV. Then hook the line to that.
Good thing is it'll provide the fresh air to the pCV but will also draw on the excess at WOT since high velocity flow over an orifice causes a slight vacuum.
I went ahead and mounted my fresh air line like this. Worked out well so far
Old May 1, 2004 | 06:03 AM
smokin' joe 00 ss's Avatar
Fireball do you have any pics of the fresh air line set up?
Thanks
Old May 2, 2004 | 07:32 AM
Back up for pics of Fireballs set up.
Old May 2, 2004 | 12:15 PM
kulablkta's Avatar
? for ya. i am looking into gettin a ls6 but have herd great things about teh lsx. i only got most bolt on as of now, but do plan on doing h/c sooner than later. would it be worth it for me to just buy the lsx now instead of the ls6?
Old May 2, 2004 | 12:21 PM
romanss's Avatar
Looks good.
Let us know how it performs.
Roman
Old May 2, 2004 | 01:21 PM
  #32
I would wait on the intake untill you get your heads or maybe a package deal for all of them. The 90mm LSX intake would be to much for a stock bolt on car wait for H/C.
Old May 2, 2004 | 01:39 PM
  #33
Fireball's Avatar
Talking
Thanks
Just snapped one for ya!
Old May 2, 2004 | 05:02 PM
  #34
Thanks, thats just how I was picturing it. My TPIS 90mm T/B and that bellows will be here this week so I'll have to do something like that.
Old May 2, 2004 | 07:16 PM
  #35
Bad30th's Avatar
Looks great !
Heh, almost looks like you're trying to hide some nitrous with the PCV fresh air line in the bellows there ! :p
Bad30th
Old May 3, 2004 | 03:10 PM
  #36
I just tallked with Texas Speed and TPIS and they both said you can run a small breather on the valve cover fresh air tube and it would be ok for a street driven car with the pcv system and that there would be no problems with the pcv system.
Old May 3, 2004 | 05:48 PM
  #37
Fireball's Avatar
I don't trust our PCV system. I read someone blew out a valvecover gasket doing that.
My setup will pull a slight vacuum at WOT to help get rid of combustion gas buildup
Old May 3, 2004 | 07:12 PM
  #38
Yea I here what your saying and I keep trying to picture what the difference would be between the fresh air hose and a small breather would be. GM hooked it up to the T/B for a reason emmissions I guess. Maybe even plug the fitting off at the valve cover and run a metco breather at the oil spout. Which way do you think the air flows from the T/B through the freash air hose to the valve cover or valve cover to the T/B?
Old May 5, 2004 | 01:17 AM
  #39
FigsZ28's Avatar
are you running a tsp 85mm lid??
Old May 5, 2004 | 07:55 PM
  #40
WILWAXU's Avatar
Yes.. he is.
