90mm LSX install complete...pics within
Old Apr 2, 2004 | 04:25 PM
Fireball's Avatar
Smile 90mm LSX install complete...pics within
Just finished up the install. Not too bad. Had some modifications required to get a the bellows I bought to work. (3.5"x4")
Took it for a spin when the roads were somewhat dry...the throttle is VERY touchy. Just a little gas makes it rip the tires in fist gear
Here are a few pics
Old Apr 2, 2004 | 04:36 PM
HumpinSS's Avatar
Cool are you attending the EFA Shootout with the new setup
Old Apr 2, 2004 | 04:45 PM
Fireball's Avatar
if its ok in the morning...I'll be there...but not racing it yet...need to tune it in first
Old Apr 2, 2004 | 04:56 PM
HumpinSS's Avatar
How much of a SOTP feeling did you get from the whole thing. Did you feel that it was a worthy mod
Old Apr 2, 2004 | 05:03 PM
Fireball's Avatar
SOTP don't work so well on low 11 second cars. I need to get it dialed in before I really rag on it
Old Apr 2, 2004 | 05:49 PM
11 Bravo's Avatar
What size maf are you running, and where did you get the bellows? I think a 90mm intake and tb, with an 85mm maf and TSP 85mm lid would be a good setup for a stroker.
Old Apr 2, 2004 | 05:51 PM
99 TA's Avatar
How are you running the tube that goes to the valve cover?
Old Apr 2, 2004 | 06:53 PM
WILWAXU's Avatar
Sweet!
Hopefully it will stop raining long enough for me to see it tomorrow
Fireball's Avatar
its dangling right now...not 100% sure what I'll do with it yet
Old Apr 2, 2004 | 06:54 PM
Fireball's Avatar
85mm maf
running this for bellows:
http://shop.airflowonline.com/Mercha...tegory_Code=HH
Old Apr 2, 2004 | 09:40 PM
11 Bravo's Avatar
Thanks for the link, Fireball. I'm going to pick one up. Your setup looks real clean, btw.
Old Apr 3, 2004 | 01:59 AM
99huggerorangeZ's Avatar
what tube??
looks awesome btw
Old Apr 3, 2004 | 04:44 AM
Fireball's Avatar
Originally Posted by my99Z/28
what tube??
looks awesome btw
The PCV fresh air inlet. It usually hooks to the nipple on the TB. The TPIS TB don't have this provision.
Old Apr 3, 2004 | 09:46 AM
ok so how are you gonna go about hooking it up??
Old Apr 3, 2004 | 09:50 AM
Fireball's Avatar
Still thinking about the best way
Old Apr 3, 2004 | 05:45 PM
CHRISPY's Avatar
good stuff
Old Apr 3, 2004 | 05:54 PM
slow's Avatar
kinda in a rock and a hard place, it is designed to be between the maf and the TB blade.
not easy to install somethign there.
good luck. Some people have claimed that they just put a breather on the valve cover, but im not a fan of doing that, it allows the possibility unmetered air into the motor.
Old Apr 4, 2004 | 08:32 AM
Fireball's Avatar
I'm thinking of putting in a 3/8" barb to 1/8" NPT connector and threading it into the bellows with some RTV. Then hook the line to that.
Good thing is it'll provide the fresh air to the pCV but will also draw on the excess at WOT since high velocity flow over an orifice causes a slight vacuum.
Old Apr 15, 2004 | 03:42 PM
Spellbound's Avatar
[QUOTE=Fireball]Just finished up the install. Not too bad. Had some modifications required to get a the bellows I bought to work. (3.5"x4")
What did you have to do to the bellows to get them to work?
Old Apr 15, 2004 | 04:34 PM
Fireball's Avatar
[QUOTE=Spellbound]
trim the angle some...other than that...they slid on with some persuasion
