push button starter wiring
http://i51.photobucket.com/albums/f3...h/9c473381.mp4
I'm also selling the start button with all the wires already set up to just plug in and go. Pm me if interested
You would then take the starter side of that wire and hook it up to one of the wires of the push button.Tape up the "key side" of the starter wire since you no longer using the key to engage the starter wire.Now splice the remaining wire of the push button to one of the main ignition wires.This way you still need to use the key to turn on all your accessories and the push button starter will only work with the key on.
Though this works 100%..there is a word of caution.First off this is not the safest way to wire it in.You risk drawing alot of amperage on that ignition wire to engage the starter circuit than its rated for.Any reputable installer would advise in using a relay trigger by ignition that draws power directly from the battery with a fuse for a fully protected circuit.
Pushbutton start, as on new cars is much more complicated, generally involving proximity sensors to detect key fob to become operational. Last time I researched this stuff a few years ago, there was no aftermarket yet. Now Flaming River has it as an option with their columns & I think separate. Think Autoloc has also had their version out for a while now, not sure who else might have something now. I just lost interest for now.
