truck intake
I have a big cam headers and ls6 intake with home ported stock tbody. 426rwhp. Is there a truck intake that makes more power than the ls6? If so, which one should i get?
Also, make no mistake about heat soak being a real issue when testing aluminum and plastic/composite manifold materials. I've personally conducted the exact testing you mention and in fact there is a 30+ degree temp difference right after a 15 second dyno pull with 180 degree water temps used as our baseline testing in every run. The aluminum intake was 125 degrees after the full power dyno sweep (cooler than the coolant temp of course due to the fuel atomization and ambient air temp flowing thru the manifold).....the composite manifold was only 92 degrees.....literally almost cool to the touch.
If you are searching for the most power from your swap....go to a 102 FAST and be done with it....out of the box worth about 5 HP over the older 90/92 design manifolds (which made the same). If your looking for all the money from the swap consider having me port one.
I know alot of folks gripe about the price, but make no mistake about the fact that cost issues aside, the FAST intake is still King and the best game in town if your looking for the most power from an intake manifold swap in a typical street/strip LS application.
Forget the truck intake btw....the stock truck intake wouldn't fit (major firewall surgery and a serious cowl hood) and its super long runners meant to produce gobs of low end torque in a truck application would kill the top end power of your combination. Now the FAST truck intake is a home run when it comes to power (its the most powerful intake FAST offers) but it also would be a nightmare to fit in a C5 (major cutting and a large hood scoop as well).
The entire FAST topic has been beat to death and I rarely post anymore when I see another similar thread pop up about it, but the bottom line is the cars making the most power on these message boards (and out in the real world) are running the FAST for a reason.....and most of the serious guys are running a ported FAST as well.
When a better manifold design comes along, you can bet your bottom dollar I will be promoting that design, highly likely porting them for even better flow and performance, and certainly running one as well on my personal project(s) also.
Keep in mind guys I have zero allegiance to FAST.....I could port whichever brand intake I choose and charge the exact same thing. My only allegiance is making the most power I can, whether we are discussing my personal stuff, or anyone else's combination I am paid to get involved in and also help optimize. I choose to port the FAST only because I have done all the research to actually know its currently the best aftermarket intake manifold available (that can be made even better with the proper shaping and porting techniques of course). Its just that simple
OP....I hope this helps....good luck with your combo and shoot me a PM if your looking for a ported optimized manifold you can bolt on and see a significant bump in your current power output. You wont regret the move I assure you
-Tony
Still remember how to do them I assure you!
Ported the 102 has about a 10 RWHP advantage btw (the new design manifold allows me more freedom with the grinder due to its completely different construction design) and is a no brainer in an F-Body which doesn't really have any issues with the install. The C5 is tight in the cowl area but there are alot of guys that have shoe horned them in. C6 is a bit easier to install.
Whichever direction you decide to go let me know and I'm sure I can help you extract the most from the swap
-Tony
