Catalytic Problems
Old Jul 21, 2012 | 06:01 PM
SLP#3766's Avatar
Default Catalytic Problems
So I was driving my 01 ss to work yesterday and the SES light popped up, I stopped at Auto Zone and they plugged into the ecu and the code we got was "PO420 Catalyst system Bank 1 below threshold"
After doing some research it looks like the drivers side catalytic converter is toast.
So I am dealt with a decision to make....
$650 for dealership install of a new one.
$200 for a off road y pipe
$500 for LT's and Y pipe
I took a look under the car today and the mani bolts look like there going to break off once I put the 1/2" ratchet on em.
What would you do and why?? Also the whole O2 sensors problem, will I need to reprogram with a off road y pipe?
Old Jul 21, 2012 | 06:56 PM
TransamGCS's Avatar
No brainier lts and y pipe more hp, better flow and with a off road pipe yes youll need to get the rear o2 sensor deleted or youll have a ses light. of course if you have emission inspection than you wont be able to use off road y. also check with the dealership some model year ls1 had a recall on cats, if they are still honoring that than you might be able to get them replaced for free.
Old Jul 22, 2012 | 11:45 AM
SLP#3766's Avatar
So if I was to go with the LT's what about the front O2 sensors?
Old Jul 22, 2012 | 06:42 PM
TransamGCS's Avatar
the front o2's will be fine you need those still on the car they will not be affected by the lt you might just have to get o2 extenders or you can buy corvette o2s the have longer conections
Old Jul 22, 2012 | 06:54 PM
SLP#3766's Avatar
So the long tubes have bungs for the O2 sensor? Sorry for all the q's...
Old Jul 23, 2012 | 06:04 AM
Way2Fast's Avatar
Yes. The lts will have O2 bungs.
