How big is the TB opening on a LS6 intake itself?
Old Jul 31, 2012 | 02:46 AM
94Z28-MSTGKLR's Avatar
Default How big is the TB opening on a LS6 intake itself?
I was looking into buying a ported throttle body for my newly aquired ls6 intake but had a question about it. How big is the actual opening to the intake? I would guess that putting a throttle body on the intake with a larger opening than the intake itself would be pointless. Am I wrong or do I not quiet understand something? Also, with a factory bellows, MAF, and SLP lid, do I need to upgrade those or are they not a restriction? I was looking into getting a different lid and a ZO6 MAF. Thanks for the help guys. I tried searching but didn't come up with the exact answer I'm looking for. Thanks for the help guys.
Old Jul 31, 2012 | 03:13 AM
99Bluz28's Avatar
I'd just add the ported gm tb, that's it, and a SSRS and a SLP/Powerbond UD crank pulley would be good to. Save the lid & MAFs upgrade for when you do a future FAST 92 or 102 intake.
Old Jul 31, 2012 | 03:19 AM
Blk98Vert's Avatar
The ported TB opening will still be the same as it was, the main point is to remove material before the blade, lighten the blade and make sure the Tb opens all the way. The stock LS6 inlet is 75mm
Old Oct 9, 2012 | 07:04 AM
Cool. Thanks guys and I have no intention to upgrade to anything else. I'm not paying the price for a FAST. I'd rather use that money to buy some SBC, LCA, PHB, and get my windows tinted for the same dollar figure if not less. Thanks for all the advice though. I've been looking for a while now and trying to find someone selling a factory throttle body that has been ported with a nice quality to it seems hard to find.
Old Oct 9, 2012 | 08:16 AM
LeanPocket's Avatar
u can always send it to tpis and get the 90mm snout
Old Oct 9, 2012 | 09:28 AM
What does something like that cost? Is it worth the price once coupled with a 90mm TB?
Old Oct 9, 2012 | 11:34 AM
LeanPocket's Avatar
350$ and it is comparable if not better than the fast 90
https://ls1tech.com/forums/generatio...-ls6-fast.html
Old Oct 9, 2012 | 11:38 AM
LeanPocket's Avatar
u just need a ftp 98 lid and a z06 maf
LeanPocket's Avatar
and matching tb
Old Oct 9, 2012 | 09:09 PM
S10xGN's Avatar
Is this pricing current or from the 2003/4 posts?
Old Oct 10, 2012 | 03:13 AM
Karl101's Avatar
check out the Shaner throttle bodies
Old Oct 10, 2012 | 09:00 AM
LeanPocket's Avatar
yes sir, i got a quote for $350
or you can buy one brand new already converted for $799
http://www.tpis.com/parts/view/39
I've seen dyno comparisons in person between the tpis vs a fast 90/90 and the numbers were dead even, but the ls6 always had more torque for some reason. so for about 650$ (used ls6 plus 90mm conversion labor) I cant get myself to buy a fast 92 or 90 for that price. Gm perfected that intake runner wise, the only advantage a fast has is the fact you can still mamofy it.. but how much is it to port a fast intake again? 350$ +/-? idk, but for my goals the 90mm ls6 is perfect for my needs.
Old Oct 10, 2012 | 07:33 PM
S10xGN's Avatar
Well, thanks for that! I have an LS-6 manifold sitting here while I've been contemplating it's future...
