High idle till i come to a stop?
I'm thinking it's a vacuum thing too given its not a voltage thing. ( the ac/fan questions leads me to that given uta not dropping when drawing the most power.) could still be an ecu program issue.
It's not mine! woo hoo!
I'm having a similar issue -- Cold start idle's around 900, and after driving it will idle up to 1000+. It also takes forever to idle down when putting the clutch in.
I don't remember what my old LS1's idled at, but this seems too high. I do have a Potz ported TB; however, it did not do this immediately after installing it.
Have no clue. Ive noticed when i shut it off it makes a hissing noise way after the car is off coming from the rear pass side of the engine. Vacuum leak back there? This is annoying. Ill go to the autozone later or something get some starter fluid and spray it everywhere to see whats up, if not im just going to go tune it. Im sort of sick and tired of this car, almost every other day its an issue.
Just got back from the autozone got starter fluid sprayed it along the WHOLE PCV system and no changes in idle. Im pretty positive this thing just needs a tune. Ill be tuning soon then.
I was holding off on tuning since i thought i had a vacuum leak, but idk why people keep suggesting its a vacuum leak, a vacuum leak is constant.
Why would the car return to idle if it was a vacuum leak?
Pontiacerator
A couple of things. First, have you disconnected your battery or reflashed your PCM? If so, this will cause the PCM to have to relearn its idle settings and the result is hanging idle. Second, there is a solenoid on the driver side of the intake manifold that has one vac line going to the MAP sensor (on the back of the intake) and another vac port for AIR. You have to cap that one off if it's not.
A couple of months ago, my car started this behavior for no apparent reason and I could never diagnose it. It gradually went away after a period of a couple of months. Here's a thread I started about it: https://ls1tech.com/forums/pcm-diagn...ghlight=cruise
Is this the hose you are refering too?
If so i plugged one of the ends of this line with a thick screw and some epoxy.
The car seems to be doing it less and less, also i still have SES light for both o2 sensors, i think i need a tune.
#39
Yeah my car idles fine as soon as i get to a dead stop, i think my car never really relearned the idle since the o2s are shot. To be honest your issue sounds vacuum leak related, try spraying starter fluid all on the PCV system and or intake, TB or any place where there WOULD be a vacuum leak. Is it consistent?
