magnaflow, hooker, or TSP true duals
Old Aug 3, 2012 | 07:54 PM
FormulaTA327's Avatar
Default magnaflow, hooker, or TSP true duals
I currently have kooks LT headers going into a crappy kooks ORY with no cats, slp plumbing with a magnaflow bullet, and it is way to raspy, sounds like a bunch of cans bouncing around in there, kind of embarrest to get down on it. wondering if i should get the magnaflow catback http://www.magnaflow.com/02product/s...ne=all&id=8919
or hooker cat back http://www.texas-speed.com/p-377-hoo...st-system.aspx
or Texas speed true duals http://www.texas-speed.com/c-137-tru...t-systems.aspx ( not sure if i can use my chassis mounted torque arm with this one)
i dont want it to loud for cruising but sound good at the same time and would like to get rid of most rasp without restricting to much flow, at wot i do want to be noticed though. any help would be appreciated
Old Aug 3, 2012 | 08:03 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Duals. Period.
Adjust them accordingly (Think MIG here) and they'll be fine. I'll never have a Y setup again.
Old Aug 3, 2012 | 09:16 PM
thinking about goin to duals, seems about the same amount of money as a cat back, off subject what unit are in dr.whigham, your rack is similar to mine
Old Aug 4, 2012 | 11:40 AM
TXZ28LS1's Avatar
Duals hands the f*ck down!!
Had magnaflow and it just wasnt even in the same sentence as duals. Magnaflow is too quiet, and even with a cam it was quiet.
If you dont go with duals, you will regret it.
Old Aug 4, 2012 | 12:39 PM
mjs1012's Avatar
i have a magnaflow and love it. the car is my dd and it is quiet when cruising and opens up at WOT. iv been thinking about duals with spiral flows, just sounds perfect. if the car is a weekend car or whatever just get the duals.
Old Aug 4, 2012 | 03:07 PM
HoLLo's Avatar
I've used and been around a lot of Fbodies with various catbacks. I've only ever heard 2 catbacks that can complete in sound quality with duals. Those 2 are the TSP Rumbler and GMMG, which are basically the same thing... I'd go with the duals.
Old Aug 4, 2012 | 08:03 PM
RevGTO's Avatar
Pontiacerator
If you go with duals, be prepared for LOUD ...
I don't like the cannon tips on the Magnaflow, but the muffler is good at cancelling out rasp.
Hooker has suffered some quality control issues recently. Other than that, it has good sound quality but is not completely effective at killing rasp.
Old Aug 5, 2012 | 06:07 AM
justin hover's Avatar
Duals are fking perfect. I've had flowmaster, and loudmouth, I wasn't about to try another catback. Instead I opted for duals like I should of the first time. While cruising it sounds soooo good, and when you get on it....It's simply sounds amazing. It's easy to let everyone know you have a top notch exhaust(best money can buy), with a slight push of the pedal.
Old Aug 5, 2012 | 11:01 AM
LeanPocket's Avatar
you have 2 options:
true duals from TSP + any muffler (call and verify if their merges are fixed now)
or the proven pat g style 3"/4" flowmaster merge w/ 4" cutout and any 3" catback.
just get a muffler shop to rework the bends if u want to use the TSP setup.
remember, x pipe outflows any y setup.
and the pat g method is the best y setup.
Old Aug 5, 2012 | 11:04 AM
Tbird232ci's Avatar
If you're looking to get rid of rasp, but not spend a lot of money, have a new merge welded in the y-pipe. A lot of the rasp comes from the merge setup.
Here is an example:
https://ls1tech.com/forums/generatio...ge-review.html
Old Aug 5, 2012 | 01:40 PM
xxKennyDxx's Avatar
Hooker Aerochamber sounds great, get the power from an upgraded exhaust and nice flowing muffler without waking up the neighborhood.
