tsp after install questions
Old Aug 5, 2012 | 11:30 PM
sstealthbomr's Avatar
Default tsp after install questions
hey fellows i have some questions regarding an install i just did, after the installation of the tsp true dual system i noticed a very rich gasoline smell while its on idling, and upon running the car felt like it didnt have any *****. i fucked up though before the initiall start up, i didnt connect one side of the coil pack connections meaning only four coils were working. as soon as inoticed this i turned off the car and connected them back. also could this have something to do with the deletion of air and egr systems. does anybody have an idea what may be the problem
Old Aug 5, 2012 | 11:48 PM
trans_am7935's Avatar
are you running cats? if not then that is why.
Old Aug 5, 2012 | 11:53 PM
no im not running cats. wow it just smelled very concentrated.
Old Aug 6, 2012 | 12:02 AM
roach4047's Avatar
I'm no expert but I've heard more than once about guys experiencing of a loss of torque at times with certain applications when a less restrictive exhaust is implemented offering less back pressure to the exhaust ports.
Old Aug 6, 2012 | 12:12 AM
i did this installation together with the 1 7/8 headers hoping this would bring out more power as opposed to stock. ill test out again this weekend coming up.
Old Aug 6, 2012 | 08:43 AM
dodson55's Avatar
bigger exhaust loses bottom end power as far as the gas smell my car smelled worse after the dumped true duals if you had exhaust ran all the way back the smell would be less noticable you can put cat on the car or if you get it retuned for the headers and exhaust and cut down on the smell some
Old Aug 6, 2012 | 05:56 PM
justin hover's Avatar
I can't even smell mine, I gained a ton all throughout the rpm range. Get tuned. It'll make a world of difference.
Old Aug 6, 2012 | 07:17 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Bingo! A tune will do wonders.
Also, I'd reset the PCM again being that you started it with only 4 cylinders firing.
Old Aug 6, 2012 | 07:51 PM
Way2Fast's Avatar
Just a thought, but if it is missing at all after running with the one bank of coils disconnected, you may have also fouled a plug. If no miss, please disregard my rambling.
Old Aug 6, 2012 | 08:56 PM
yeah im gonna head straight to the tuners as soon as i can. i was just in a hurry to get this stuff done,i have the car 50 miles away from were i live and it seems its gonna take all damn summer to get this **** straightened out. i get to go on weekends only and my *** thought before doing all that i should replace motor mounts lets just say i got a good asswhoopin.
