Best heads for my set up?
We told the customer if he wanted to really put down a number to bring it back in October or November and we would put the timing back to 28* and lean it out a few tenths and put that 475rwhp number up on the board. I have no doubt that with an electric water pump and a ported Fast 102 it would of made 480 at the tire in the heat and over 490 in the cool?
What heads should I go with?
An after market head has lots of benifits. Including HP's.. Nothing is worse than sitting there after that first test drive and knowing you left a good bit on the table
Its only money, imo.... An after market head has lots of benifits. Including HP's.. Nothing is worse than sitting there after that first test drive and knowing you left a good bit on the table
Its only money, imo....That was through a M6 FWIW and it was HOT outside and HUMID! 98* and nearly 80% so we had to back off of the tune AFR wise and timing wise to keep it safe.
I'm completely sure it would make 475+ in the cooler fall months with a slightly leaner AFR and 1-2* more timing.
