Best heads for my set up?
What heads should I go with?
Unless you know someone that will give you a great deal on port work, it will be very hard to beat the price they are offering.
He said mine were worth about 10 HP, the 2.5's were worth 15, over stock. He said hands down the as cast Trick Flow 220's were the best bang for the buck and worth 40-45hp over stock.
Well...the TSP 1.0s are $1,200...so not too much more than that. I won't know my actual budget(no less than 1,200 for sure) until I hear from the people at the shop regarding what all ha/had to be done. Let's say 1,500 to be safe tho ha
You can also price out maybe getting a cheap set of stock ones from the parts classifieds and seeing what other companies would charge you like TEA or AI and compare the pricing and the options and what all each company does during their porting process.
That is what I would do at least.
Tony Mamo himself has spent countless weeks and months doing little things here and little things there to reach 480-490 and the amount of work it took to get over the 500rwhp hump is incredible.
Here is a package we did for a customer last month: TEA CNC TFS 215's, Fast 102 and our Polluter cam...
Keep in mind this was in nearly 100 degree weather and 75%+ humidity numbers will be much higher when it cools off, probably in the 475 range easily if not more. This Fast was completely unported. With a electric water pump and a ported Fast you could see 480-490 I would say.
