Help me decide
Old Aug 9, 2012 | 04:10 PM
AMS13's Avatar
Default Help me decide
I currently have BBK long tubes on my car with a TSP Rumbler that I hacked up and put a FM super 10 in. I don't know if I did this while putting the Flowmaster in, or if this is just the nature of the beast, but I have a good amount of rasp. Here are my options to try and squeak more power/better sound out out of this setup.
1. True duals with fm 10's dumped @ the axle.
2. Weld in a Flowmaster merge with a 3 1/2 inch outlet and run a single exhaust with a fm 10 dumped at the axle.
3. leave the y pipe alone and do the 3 1/2 inch or the 4 inch Mufflex with the Spintech.
4. Pull the tailpipes off and run the current exhaust dumped at the axle.
I am some what leaning towards the Mufflex only because I have a 3y/o that rides in the car often, and I don't think its a good idea to run a dump if he will be riding along. I am open to all suggestions, the car also has a 228R cam.
Old Aug 9, 2012 | 05:57 PM
sokr915's Avatar
I saw you do buy a dif cam and put a turbo on it.
Old Aug 13, 2012 | 12:21 AM
99Bluz28's Avatar
Run the FM 2.5"/3.5" y-merger into a Mufflex 3.5" exhaust system. You'll gain some power with this as long as you run a high flow muffler.
Another option is to run a magnaflow #12867($93) 3" in/out 5"dia., 14" case muffler right off the bbk y-pipe exit and dumped before the axle tubes just like in the photo, with a J or U bend (#SUMmit-622005)that has been cut in half at the middle of the bend, flipped not quite 170*and rewelded so the exit is only pointed slightly downward. You won't gain any power, but there wont be any drone.
http://i523.photobucket.com/albums/w...exhaust003.jpg
http://i523.photobucket.com/albums/w...exhaust005.jpg
Here's how mine sounded with the Magnaflow dumped, inside the car no drone and it wasn't really loud.
http://s523.photobucket.com/albums/w...nt=CAM2001.mp4
Old Aug 13, 2012 | 11:27 AM
Siciliano15's Avatar
since when do u wanna get rid of rasp? haha
