What lid with fast 102 setup?
Old Aug 12, 2012 | 12:16 PM
Turbo306Fox's Avatar
Default What lid with fast 102 setup?
Im about to swap to a fast 102 setup and I have the slp lid seems like I need a bigger one but with all the problems with the ftp 104mm cracking im not sure what to do?
Old Aug 12, 2012 | 05:34 PM
therabidweasel's Avatar
Buy the ftp new and it will be under warranty. As long as they stand behind it, why not? It's a lid, not a crank.
Old Aug 12, 2012 | 07:38 PM
ULTIMATEORANGESS's Avatar
i just kept my whisper lid from my old setup.
Old Aug 12, 2012 | 08:08 PM
SpinsB's Avatar
FTP has a warrenty on lids?
Old Aug 12, 2012 | 08:29 PM
Jay-P's Avatar
As long as you bought it new, not used. They will take care of you if there is a defect.
Old Aug 12, 2012 | 08:47 PM
Sales1@Texas-speed's Avatar
I would recommend the FTP lid. While some have had issues with theirs I've never had an issue with them. Just make sure to not over tighten the clamp when putting everything back together.
Old Aug 12, 2012 | 10:02 PM
Yea if they warranty it I have no problem getting one
Old Aug 13, 2012 | 12:11 AM
backdraft408's Avatar
ftp is what im running. havent had a problem yet
Old Aug 13, 2012 | 12:16 PM
01'SSLSX's Avatar
ftp FTW!
also if your using a stock maf, I would upgrade to bigger size
Old Aug 13, 2012 | 12:38 PM
Fast Toys Performance Parts's Avatar
Yes we do!
As Aaron from TSP said, it's important to not overtighten the band clamp on the neck. It just needs to be snug.
Old Aug 13, 2012 | 01:18 PM
raysadude's Avatar
FTP 98mm lid here with FAST102, fits perfect with Delphi 85mm MAF
Old Aug 13, 2012 | 04:00 PM
I got speed density
Old Aug 14, 2012 | 11:40 AM
Originally Posted by Turbo306Fox
I got speed density
For SD cars, use the 98mm Air Lid.
Old Aug 14, 2012 | 03:49 PM
Why is that? I have slp lid now what mm is it?
Old Aug 14, 2012 | 03:52 PM
The SLP Lids has the same outlet size as the stock lid. The FTP lid has a larger outlet size and larger internal dimensions to support motors that produce more power.
You can read all the tech specs here:
http://fasttoys.net/shop/Fast-Toys-B...-Firebird-LS1/
Old Aug 21, 2012 | 12:56 PM
Sube's Avatar
Why do you need to use a 98mm for SD? I haven't put it on yet but I already have a FTP 104mm, will that still work? I am SD tuned.
Old Aug 21, 2012 | 01:01 PM
JakeFusion's Avatar
Super Hulk Smash
I'd use the Fast Toys 104 and get the TSP 100mm MAF. No restrictions with that setup and if you have a competent tuner, you can run off the MAF at idle and part throttle and SD WOT and be able to drive with no issues no matter the weather.
Plus the TSP MAF kit comes with the silicone coupler for the 102mm TB, so you'd have a plug and play kit from airbox to TB.
Old Aug 22, 2012 | 05:40 AM
Jake, I take it your silicone coupler was long enough? Mine was probably 1.5 inches too short.
