lt install
Old Apr 5, 2004 | 03:43 PM
1le II's Avatar
Default lt install
I know its been asked many times before, Any tips or tricks? I've got the stock exhust off, also doing a plug change. I assume the new plugs go in after the header is on. I know the work is just starting so any advice would help. The car is 28 inches off the ground,i'm not in a hurry. Every thing has gone well to this point. Thanks for ALL HELP.
Old Apr 5, 2004 | 03:57 PM
foff667's Avatar
LS1TECH Sponsor
check out my sig for my install notes...thats a good place to start
Old Apr 5, 2004 | 04:02 PM
99-LS1-SS's Avatar
STF Veteran
Old Apr 5, 2004 | 05:35 PM
S2002S's Avatar
I changed the plugs before installing the headers...it is much easier. The trick is getting the car high enough! I had to get the "nose" up 32-36 inches off of the ground.
Old Apr 5, 2004 | 06:38 PM
2002 Trans Am's Avatar
I'm not exactly sure why the guys on this board say to put the spark plug back in after you screwed in the headers, but they do say it.
Personally I think it is easier to do it while the headers are off, just be careful not to hit the plugs while putting the headers in I guess.
Oh yeah disconnect the battery too. Header installs are fun
Old Apr 5, 2004 | 07:45 PM
CamaroCain's Avatar
if you know it has been asked many times, try doing a search in this forum for "header install" or something along those lines
Old Apr 5, 2004 | 07:51 PM
1le II's Avatar
foff667:thanks for the photos. S2002S: I will change the plugs first, and get the noise higher to start with. I'm using kooks any clerance issues? If so what? 2002 Trans Am:Thats 2 plugs first,Thanks and it is FUUNNNN!!!!
Old Apr 5, 2004 | 07:57 PM
1le II's Avatar
CamaroCain:Had a bad day?? LIFE IS SHORT BE HAPPY
Old Apr 5, 2004 | 08:50 PM
WILWAXU's Avatar
She was trying to be polite and get you to use the search feature for a question that's asked a couple hundred times this week
If she was really having a bad day, she could have just locked/deleted your thread for you
