Is there a better MAF then the SLP 85mm? Pro-M???
what about Pro-M anyone ever dyno after putting one of these on?
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
MAF frequency axis going out through 12000Hz on my
'01 F-body. So that means no prob using the Delphi
85mm. Truck MAF table for screened, Z06 table for
descreened should get you pretty durn close. As for
the aftermarket companies who don't bother to provide
their customers a valid MAF table to tune with, I say
fuzzy yarbles to ya, Mr. G. and Mr. S. Dirt cheap Delphi
will flow as well and is a known quantity. No offense to
our fine sponsors, who only can deliver what is made.
Perhaps some of them might do good business if they
had Z06 MAFs for sale kitted up.
looks like its back to the slp 85mm
I had it before and it worked great no problems
so is there a difference between the SLP 85mm and Pace 85 LS6 ? Same?
I had the SLP that was for the 2001 LS1's before
and I just got a 85mm lid from you guys at TSP cant wait to finally put all this stuff together
a descreened Delphi 85mm with a resistor, same
idea as the SLP (though SLP leaves the screen in).
Don't know whether they use the same or different
resistor value. But to get something that matches
the stock calibration within a few percent, there
is a pretty narrow range of resistor value options.
I would stick with the one you've got, for now; if
you were getting tuned I would suggest removing
the resistor and having the tuner (or you, if you
is him) substitute a truck MAF table into your
PCM calibration file. I haven't found yet how well
the SLP vs stock lines up all across the airflow
band; only that WOT and LTFTs seem "close
enough". But the MAF table that GM thinks is
right for the base unit has got to be a better
fit than the table for another MAF against the
85mm and resistor tacked on.
Not quite clear on your situation but, if you
have to go bu a new MAF, I would go buy a
factory new Z06 off gmpartsdirect and scrounge
up a MAF table to match (off the LS1Tuning or
HPTuners boards or right here). You'll come out a
bit cheaper than any aftermarket one, and it'll be
an unmolested virgin of known good character.
What more could a sick freak want?
So maybe the slp will be best for now
