243 Heads Help
Old Aug 21, 2012 | 02:04 PM
Stilo's Avatar
Default 243 Heads Help
Just bought these 243 heads on CL for $200, the guy i bought them from said he built a 5.3 truck eng and put these on, and a few min after starting the enging he started to hear noizes and turned out he blow 2 rods and bent 3 valves on these 243. He bought them from a shop that did a valve job before and said they refaced them but didnt mill them but he was not sure. I went to a local shop but they said they didnt look to be milled but they were not 100% sure. I would like to put these on my LS1 and swap out my 853 for 243 with TSP 224r and LS6 intake.
CAN ANY ONE TELL IF THESE HEADS HAVE BEEN MILLED THE LOOK STOCK BUT IM NOT SURE! THANKS
Old Aug 21, 2012 | 02:11 PM
scarybowtie's Avatar
Best thing to do would be to have someone cc the chamber. But I'll try and rember to put the calipers on mine this afternoon
Old Aug 21, 2012 | 04:53 PM
Stilo's Avatar
How much do CC test run and if some one has a set of 243 heads can you take pics of the intakes so i can see if they match mine, Thanks
Old Aug 22, 2012 | 12:04 PM
Stilo's Avatar
I seen a few other post most say that the stock length is 4.75 on unmilled 243 heads, can any one confirm this?
243 Specs
Casting Number 243
LS6/LS2
01+ 5.7L Corvette/05-07 6.0 Corvette
Material: Aluminum
Combustion Chamber Volume: 64.45cc
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Old Aug 22, 2012 | 02:50 PM
RezinTexas's Avatar
you can measure the cc's yourself for less than $5 and 5 minutes. engine oil, cold medicine syringe, plexiglass, grease for seal between plexiglass and head deck. if done carefully, it is extremely accurate.
Old Aug 28, 2012 | 03:00 PM
SickDenali's Avatar
Mine are milled .030 I'll try to get a measurement for you to compare to.
Old Aug 28, 2012 | 09:16 PM
bayer-z28's Avatar
Yep.. Only way to tell.
Old Aug 28, 2012 | 09:38 PM
garygnu's Avatar
you can buy a piece of plexy glass and cc them your self.get a piece big enough to use 4 bolts to hold it tight.drill a small hole to add fluid.you can get the needle from a pharmacy.
