Swapped from LS6 to FAST 102...now have idle problems...UPDATED!!
Hello all,
I just swapped my intake from an LS6 to a FAST 102/PPS 102 TB from Speed Inc. and, as usual, I now have a problem. When I crank the car up, the rpms immediately jump to about ~2200 rpm then slowly idle down to about 1200 rpm. After it sits for about 30-45 secs, the rpms will begin to slowly climb to as much as 3k before I shut it off. Rpms also tend to increase if I put it in 1st gear.
What I have done to troubleshoot the problem:
1) Sprayed carb cleaner around the base of the intake, as much as the pcv lines as possible to get to. Have not noticed any difference in idle speed as one would expect.
2) Retorqued Intake bolts to ensure proper seal.
3) TPS relearn for the 102 TB.
4) Inspected all vacuum lines to ensure everything is connected.
I know people have swapped these intakes and ran the 102s without a tune, so while I know it indeed needs to be retuned, I feel that there is a bigger problem somewhere.
Any help is greatly appreciated!
I have never heard of someone not tuning the car after a 90mm intake install, let alone a 102 (which is even harder to tune). If the car has not been tuned then I am going to assume thats the problem....
I'll try unhooking the battery though, hadnt thought about that. How long should I unhook it for? 30 secs? 30 mins? I was going to try driving it earlier but I was scared to pull out my driveway on the busy main road
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
My thoughts exactly. I plan on having it tuned as soon as I can, but the problem is that this thing is going to drive TERRIBLE on the way there.
I'll try unhooking the battery though, hadnt thought about that. How long should I unhook it for? 30 secs? 30 mins? I was going to try driving it earlier but I was scared to pull out my driveway on the busy main road![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Sorry if it seems like a noob problem. I've done a couple of intake swaps on cars before but never really had any issues like this. I just want to make sure that when I take it to my tuner that there isn't a problem somewhere that needs to be resolved before tuning can take place.
I had thought about this as well. The 102 TB (as you would expect) fully closed allows much more air in than my old stock P/P did, so it makes complete sense that it would idle higher. I was under the impression that the relearn would compensate for this. I could be completely wrong. Going back to the original post...if this is why it idles higher, what could be causing it to randomly increase idle speed after a short period of time? Just the fact that its untuned?
HiOSSilver:
Sure...but I have a sneaking suspicion I'm about to get rick rolled..
gary:
It isn't SUPER tight. It has a little wiggle in it, but I did put a bolt and a washer on it to keep it tight. I guess its possible that it wiggled loose during the install...
Thanks for your help guys, keep it coming!
Ok, so I went to Advance to get them to run a scan and see what codes it threw. I cranked up the car and it seemed to be running OK minus the fact that its idling at 1300 rpm. Advance was less than a mile away, but when I came back it was a different story. The car seemed to be running OK under load, but when I push the clutch in it goes to about 3000 rpms. Also, it seemed to be driving itself when I wasn't touching the gas and it sounded to me like there was a tick/sucking noise while driving. If I were a betting man, I'd say there is a leak somewhere...I just can't find it ANYWHERE.
PO122 (TPS low voltage)
PO412 (secondary air injection switching valve a circuit)
PO507 (iac system revolutions per minute higher than expected)
Here is some other info that may or may not be useful to you guys..
MAF= 2.45
MAP= 2.4
Going back to my cammed LT1 T/A, my scanmaster would read MAP at 8-9, so in comparison this seems low (which may mean low pressure=leak, right?). I have no idea if these units are the same though...
MAF= 2.45
MAP= 2.4
