GMPP LS1 Intake - Availbility Update
Old Apr 29, 2004 | 06:48 PM
Solid346's Avatar
sweet.. thanks bro, hoping for the best..
Old Apr 29, 2004 | 07:36 PM
Speedfreaks101's Avatar
Any results?
Old Apr 29, 2004 | 09:10 PM
D Rock's Avatar
I can't wait to see these results.
Old May 1, 2004 | 05:49 PM
D Rock's Avatar
Results?
Old May 1, 2004 | 05:58 PM
Cmarsh93z's Avatar
Not yet..still some detailing on the car to get done.
Chris
Old May 1, 2004 | 09:18 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Very interesting!
Going to run a speed density tune?
Old May 4, 2004 | 07:21 AM
99 Black Bird T/A's Avatar
That look so cool!
I can't wait to hear about the results!
BTW - several hundred are in the pipeline from GM for GM Performance Parts
Old May 4, 2004 | 09:01 AM
Bad30th's Avatar
Originally Posted by Cmarsh93z
I'll let ya'll know how it works
Chris
Bad30th
Old May 4, 2004 | 07:51 PM
WMSuperSport's Avatar
dying to see some numbers...
Old May 4, 2004 | 08:00 PM
Chris@AP-Engineering's Avatar
Under criminal investigation for fraud
Wade, I can get these intakes all day long. I have two at the shop now. If you need one let me know.
Thanks
Old May 5, 2004 | 02:51 PM
Pacific Muscle Cars's Avatar
It's difficult to tell from the picture, but is there enough clearance under the cowl to fit an air cleaner on that throttle body?
Just a thought - does anyone know if there is adequate clearance to use a 90 degree elbow and stock-style throttle body?
Old May 8, 2004 | 12:46 AM
  #32
ttt...
Old May 9, 2004 | 08:52 AM
  #33
Cmarsh93z's Avatar
No dyno results.....went to the track friday night, and ran a 5.99 @ 114.50 in the 1/8. We are upgradeing the heads right to a copper/oring setup, so we will probably be back on the road in a week or so. Intake works really good, just can't give a XXXX percent over the Ls6. Maybe I will throw it on another car in the next few days and test it.
Chris
Old May 9, 2004 | 12:13 PM
  #34
damn it.
Old May 9, 2004 | 03:58 PM
  #35
Cmarsh93z's Avatar
As for clearance, you aren't going to be able to do a elbow with the stock cowl. It has just enough space for the TB we are running...and if you wanted to put an elbow on there, you would have to custom make it really low profile, or have a cowl hood.
Chris
Old May 9, 2004 | 05:17 PM
  #36
Ryan K's Avatar
Pathological Modifier
https://ls1tech.com/forums/generation-iii-external-engine/168311-war-intake-accel-teaser-pictures.html
I don't think there is any way to run it without cutting the cowl. This is a hardcore intake and requires some hardcore modifications to run it.
Ryan K.
Old May 10, 2004 | 11:00 AM
  #37
No offense but it doesn't seem that all that work and money is worth ~.01 seconds in the 1/8.
Just my .02
Old May 11, 2004 | 07:02 AM
  #38
WILWAXU's Avatar
Dyno results:
https://ls1tech.com/forums/dynamometer-results-comparisons/170243-war-intake-dyno-results.html
