Poly motor and trams mounts...
I have a loud buzzing vibe at idle, but its goes away if you crack the throttle a bit, or if you are on the move... I have had ZERO problems. No weird vibrations at any speed. Nothing. Its a worth while upgrade IF you do it right.
I've been running this setup for a while now (8 months+) with lots of WOT runs. Again, zero problems.
I will be upgrading to poly motor mounts when I install my headers.
Aside from a bit more vibrations, I didn't notice any new issues with the solid mounts. Course, so much **** rattles inside from the dual drone that it tends to drown other things out. The solid mounts did get rid of "low-gear lurch" when I was in 1st or 2nd gear but off the throttle (typically in traffic). Best way I can describe it is that it felt like the whole driveline would bind up, then lurch forwards, until I gave the car a bit of throttle. Damned annoying.
The car definitely feels better and I hear you on the driveline lurch! I got tired of feeling/hearing it, the old rubber mounts were shot to ****. I have had ZERO problems. No weird vibrations at any speed. Nothing. Its a worth while upgrade IF you do it right.
just letting you know your asking for trouble stock rubber mounts and a poly trans mount. ive seen alot of people run that and crack the tailshaft of the housing. The rubber motor mounts alow the motor to flex and the poly trans mount holds it stiff easy figure out what will happen
My mount comes on Wed., I will make sure not to use the spacer and grind the bumps if it has em.
I have stock MM's and poly TM. Been this way for over a year with a few runs at the track and no problems.
As far as the vibration, it does a little but not that bad, definitely tolerable. At 65-70 it vibrates the most, other than that you really don't even notice it.
Hope I don't break anything this way
I had poly mounts on both and The only problem is the shifter vibrates a little more. Big deal. It's a camaro not a Lexus.
I myself run a Prothane and love the thing. When I took my stocker out I was SHOCKED at it's condition, as well as the rubber motor mounts.
Spohn solids and Prothane Trans mount.... no complaints here. It's very subjective to your own tolerances though.
I may just replace current motor mounts with a new set of OEM mounts, unless there is some advantage to be had with poly ones.
Another plus to this setup is Im going to go duals, and this would let me tuck that setup very close to the body.
