Jet Hot catted Y Pipe install pics? Jet Hot guys inside please!
Hey guys! Do any of you guys that have Jet Hot LTs and their catted Y pipe have some good pics on the Y pipe put together, or how it goes together properly? Also, some pics of it installed on your car would be great as well! I'm pretty sure I have it right, but I just want to make sure. Also, any other changes you did with yours, like different clamps or anything? Thanks a lot guys!
I like to cntl-c/cntl-v I could do this all day long ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Search my username for more help:
Get TWO 3inch BUTT Joint Stainless Steel Band Clamps for the cats, and ONE 3inch SLIP Joint Stainless Steel Band Clamp for the driver side Y-pipe. I got these all at Napa, they are the same brand that came w/ my header kit. Make sure you get stainless, cause they also carry alumin. I think they are Torx brand or something. Just make em pull out the catalog and order if they don't have em.
This way you can use the TWO 3inch SLIP Joint connectors that come w/ the kit to use @ the collectors.
At least that's what I did. I used one of the 3inch U clamps for the Y-pipe to I-pipe.
This pic makes sense of it all
![](http://www.jet-hot.com/images/50800.jpg)
So going from top to bottom:
__________3 inch U clamp
_____________________3inch SLIP
3inch BUTT____________3inch BUTT
3inch SLIP_____________3inch SLIP
