102 intake problems
Old Oct 3, 2012 | 12:30 PM
Travose21's Avatar
Default 102 intake problems
my injectors wont seem to fit down the intake injector ports. someone please chime in
Attached Thumbnails 102 intake problems-injectorrrrr.jpg   102 intake problems-injectorsssssssssssss.jpg
Old Oct 3, 2012 | 03:11 PM
Undertow74's Avatar
If they are not the skinny pencil style injectors, but the fatter SVO injectors, you will need to trim around the topside of the injector port to get them to fit right
Old Oct 3, 2012 | 03:35 PM
Travose21's Avatar
so i dont need to buy a new set of injectors right.
Old Oct 3, 2012 | 03:42 PM
Undertow74's Avatar
you shouldn't have to, i have the pencil style injectors on mine and they fit no problem. from what i have seen with the fatter injectors you have to trim the top edge around the injector boss where the upper shell meets the lower to get them to fit correctly
Old Oct 3, 2012 | 05:39 PM
parks450's Avatar
Do not trim the intake, you need o-ring adaptors, I have has to buy them. Call fuel injector connection (FCI) and they will hook you up
Old Oct 3, 2012 | 07:10 PM
raysadude's Avatar
I trim the upper edge with mine, there's plenty material there don't worry about trimming.
Old Oct 3, 2012 | 07:15 PM
raysadude's Avatar
Oh I have the fat fast injectors
Old Oct 3, 2012 | 07:24 PM
Travose21's Avatar
me to i have the fat short fast 42lb injectors
Old Oct 3, 2012 | 07:31 PM
SweetS10V8's Avatar
Id buy injectors that are actually designed to work with the intake. Not modify the intake to fit injectors it wasnt designed to be used with.
Old Oct 3, 2012 | 07:33 PM
raysadude's Avatar
I agree if you got the means then buy ls2 injectors that the intake is designed for
Old Oct 3, 2012 | 11:14 PM
Travose21's Avatar
I ordered the long style 42lb injectors thanks guys
Old Oct 4, 2012 | 08:48 AM
badazz81z28's Avatar
Is that not OK? Thats how my LS1 injectors fit in the 102 intake....I'm using LS1 injectors w/FAST provided O-rings for such injectors.
Old Oct 4, 2012 | 10:03 AM
Travose21's Avatar
i was told that its not
Old Oct 4, 2012 | 10:37 AM
From who? I would call FAST and ask....
Mine looks just like that, and CPG said I can use my stock LS1 injectors as long as I use their O-rings...
Old Oct 4, 2012 | 03:17 PM
Travose21's Avatar
these are the ones i took out
Attached Thumbnails 102 intake problems-ssssssssssssssssssssssssssssssssssss.jpg   102 intake problems-iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii.jpg
Old Oct 4, 2012 | 03:35 PM
Did you call Comp Perf Group? (FAST)?
Old Oct 4, 2012 | 07:07 PM
Travose21's Avatar
yes and they said that mine would work but it wont run to the best performance because its not getting all the fuel to the valves and is too far back
Old Oct 5, 2012 | 01:35 PM
Who did you talk to? Its an FI system...Fuel is sprayed into the runner, not the valve. There are tons of people not running the pencil tip LS2/LS3 injectors with this intake w/no issues.
