160 degree thermostat question
Old Apr 9, 2004 | 02:19 PM
MARKSZ71's Avatar
Default 160 degree thermostat question
i put a 160 thermo in my 01 Z and it still reads about 195 on the guage i got all the air out i could any commmets or suggestions thanks guys.I also have the lower fan tems adjusted
Old Apr 9, 2004 | 02:32 PM
Termin8r27's Avatar
How did you adjust the fans? Some have installed the Hypertech and Predator and they have not held the tune... Also, the temperature guages in our cars have been known to be false pretty often and just read around 200 degrees all the time once it warms up.
Old Apr 9, 2004 | 02:34 PM
95_Firehawk_Dude's Avatar
Get your PCM tuned maybe?????
Old Apr 9, 2004 | 02:37 PM
MARKSZ71's Avatar
speedinc did a basic tune and changed the fan settings to come on earlier
Old Apr 9, 2004 | 02:39 PM
Termin8r27's Avatar
I would then say use some type of scanner and check the actual fluid temp if you can/want. Again, our temp. guages have been known to false read.
Old Apr 9, 2004 | 03:11 PM
slow's Avatar
99+ temp gauges are idiot lights, basically.
from 185-228 they should point to 210, not sure why yours runs at 195?
ryan
Old Apr 9, 2004 | 04:01 PM
ws6dude's Avatar
My gauge never changes, but when I look at the temp through the Predator it is much lower
Old Apr 9, 2004 | 08:15 PM
WS6FirebirdTA00's Avatar
how are u getting numbers? off software or what? and your fan temps might not be low enought. cruise for a while and see how low they go. in cold weather i run about 167
Old Apr 10, 2004 | 01:44 PM
MARKSZ71's Avatar
a gm tech 2 scanner will go back and check monday i did pump the air out of it thanks guys
Old Apr 10, 2004 | 02:20 PM
Hawkeye2's Avatar
As already mentioned, the 98 has a real gauge from 99 and up they just
show a "normal" reading.
The 160 stat just means it opens earlier, at 160 instead of a higher temperature. It will not keep the engine coolant temperature lower than
what the operation of the engine calls for, due to driving conditions etc.
It just opens sooner, which should translate to cooler running, but giving
certain conditions, it will still run at normal operating temperatures.
Old Apr 11, 2004 | 09:58 AM
StevieZ's Avatar
Gauges on a 98 are not that accurate either!
Old Apr 11, 2004 | 12:09 PM
my freinds 98 reads 160-180 when predator shows 220, i think they are the worst
Old Apr 11, 2004 | 08:47 PM
MARKSZ71's Avatar
thanks guys
