1 7/8 vs 2 headers
Old Oct 9, 2012 | 11:22 PM
joshua.lacy's Avatar
Default 1 7/8 vs 2 headers
What would be better for my car 1 7/8In headers or 2in headers? Eventually I'm going to do heads and cams
Old Oct 10, 2012 | 12:56 AM
94Z28-MSTGKLR's Avatar
Need some more information about your car. Is it a stock LS1 with the future of a heads and cam setup or do you plan to stick in a 400+c.i. in with forced induction? 1 7/8's are probably your best bet reguarless of the setup you have planned unless you expect to be pumping a ridiculous amount of air through your engine, and keep in mind a massive exhaust set up is no good if your intake won't allow more in. Tell us about your ride, the way it is now and your ideal future mods.
Old Oct 10, 2012 | 10:50 AM
I have a 2001 Firebird. I'm about to put on a FAST 102mm intake manifold and a 92mm throttle body. I plan on putting on heads and cams in the future.
Old Oct 10, 2012 | 11:53 AM
1 7/8 is plenty. The restriction is going to be what you run after the collectors such as a "Y pipe" or "True Duals".
Old Oct 16, 2012 | 03:24 PM
Cool Thanks.
