2000 ws6 intake swap
Old Oct 10, 2012 | 01:41 PM
eddieoley's Avatar
Default 2000 ws6 intake swap
Im wanting to swap out the ls1 intake and go with an ls6 intake. What all would i need to complete this swap.. thanks for any tips
Old Oct 10, 2012 | 03:18 PM
Nathan C's Avatar
I believe if you get rid of the EGR valve you will throw a check engine light, so you will need to get it tuned to eliminate the light. Not sure about the rest, but there should be a sticky on it.
Old Oct 12, 2012 | 06:20 PM
juicestain's Avatar
If you grind the bottom of the LS6 then it should just replace the old one. Removing EGR will make it easier and you will not have to drill a new hole in the intake. But, if you don't grind down the the bottom of the LS6 you will need the LS6 coolant crossover kit. I got mine from Texas Speed. There's alot of good info on this site and google on this process I think there's even some YouTube videos. Good luck
Old Oct 12, 2012 | 08:50 PM
s346k's Avatar
i used a wood chisel and hammer on those fins. they knock off very easily. after knocking all them off as flush as i could get them i hit it with some 100 grit? (found it in the garage) sandpaper. it turned out stellar.
