Starter Bolt Issue!!
Old Oct 12, 2012 | 10:05 PM
badazz81z28's Avatar
Default Starter Bolt Issue!!
Hey All,
Does anyone know the correct part # for the 113mm M10 starter bolts?
I bought the Dorman bolts and they have less thread grip (possibly bottom out) than OEM and are grade 9.8 bolts vs the grade 10.9 GM....
No wonder they are only a couple bucks....
Old Oct 12, 2012 | 10:15 PM
Pictures
Attached Thumbnails Starter Bolt Issue!!-starter1.jpg   Starter Bolt Issue!!-starter2.jpg   Starter Bolt Issue!!-starer3.jpg
Old Oct 12, 2012 | 10:35 PM
weaklt1's Avatar
i just bought some from the local gm dealer. they were only about $5 each.
Old Oct 12, 2012 | 10:50 PM
Do you recall the part #?
Old Oct 13, 2012 | 01:46 AM
01ssreda4's Avatar
Those Dorman bolts work fine. Are they the ones for like a GM 2.5 4 cyl or whatever. Ran those on a ton of engines. Your block or starter casting will break before that bolt will.
Old Oct 13, 2012 | 10:38 AM
Yeah I know, the steel is a lot stronger than the alum, just want the proper grade (I'm **** like that"...My main concern is the thread grip.
