CHRS1313 install questions.
Old Oct 12, 2012 | 08:46 AM
VandykeT/A's Avatar
Default CHRS1313 install questions.
I just got mine yesterday and I started putting it in. I've all ready pulled all my a/c stuff . I cut the V bracket, bent the tab on the bottom toward the back of the car and took a big cresent wrench and bent the upper radiator support toward the front of the car and slid the scoop in from the bottom. My question is am I suppose to attach it to the lower air box first then slide everything in from the top or am I suppose to wiggle the scoop in then sit the lower air box on top of it. I actually put the scoop in from the bottom because it didn't seem to want to go from the top but then again I didn't try very hard. Also on modifying of the lower airbox, if I all ready had the free ram air mod I won't need to do anything else to it right? Sorry for the stupid questions I was messing with this in the dark and I wanted to make sure I had all my ducks in a row when I tore back into it. Thanks
Old Oct 12, 2012 | 07:03 PM
3rdgen92maro's Avatar
Heres a link to the instructions...
http://speedinc.com/pdf/Ram_Air_Install_No_AC.pdf
