243s to 862s ???
Old Oct 14, 2012 | 01:31 PM
InsaneDomestics's Avatar
Question 243s to 862s ???
I have a 4.8 with the 243 Heads, if I were to ditch those and install a set of 862s this would bump up my compression correct?
If so, how much?
This is in my CC Truck and it's a dog off the line, would this help or make things worse?
Unfortuneately I got a long road ahead of me until I can afford a Turbo kit so I need help getting as much N/A out of this little bastard as possible.
Any suggestions?
Old Oct 14, 2012 | 02:55 PM
parks450's Avatar
It will hurt you, 243's flow the best out of cathedral port heads. My advice is if your actually going to turbo get a set of 317 heads and have them cnc'ed or just use them as you'll need lower compression for a turbo. If you throw those heads on now you'll most likely have to replace them to lower your compression for turbo, unless that's what you plan to do anyways. Either way you'll lose a decent amount of power swapping to 862 heads
Old Oct 14, 2012 | 05:54 PM
Ugh, thats not what I wanted to hear... Any other suggestions to help with the low end on this 4.8?
Old Oct 14, 2012 | 07:09 PM
jimmyblue's Avatar
Moderator
I would be looking into the burst knock setup, I've seen
that pull timing on an older ('99) truck big time in 1st
gear. Trucks also get a crappy timing table and PE mode
held off, from the factory. The burst knock delta cylinder
air value wants doubled, at least, to keep you from the
spark pull under hard acceleration - it's supposed to be
dealing with opening-throttle, but the air mass run-up
with RPM (following VE slope) triggers it too if the BK
threshold is too low (like the trucks' 0.010 value). If you
set it like a car it'll drive like a car, or more so.
Now a fat body and the likely tall gears that the fuel-
sipper motor option probably gets you, don't help
either. But those are more difficult to do much about
on the cheap.
