Fuel pump check valve
Old Oct 15, 2012 | 04:22 PM
LWCS561's Avatar
Default Fuel pump check valve
I recently went to replace my fuel pump with the racetronix pump. When putting everything back together, we put a little gas in the bucket to see if the check valve was good or not, and gas came out the bottom. I called up local parts shops and sure enough, no one sells just the valve at the bottom. Has anyone had their check valve go bad? Is there a way to just buy the valve, or do you have to buy the whole bucket?
Old Oct 18, 2012 | 12:44 PM
LWCS561's Avatar
anyone?
Old Oct 18, 2012 | 01:19 PM
thunderstruck507's Avatar
I've never heard of them being sold separately. The one in my Silverado is bad and it's a pain in the butt because you have to prime the truck 2-3 times before it will start.
I'm thinking of trying an external check valve in the fuel line for $40 instead of a $250 POS fuel pump that may or may not get the same problem within a year.
