at what point do u need better injectors?
Old Oct 26, 2012 | 02:16 PM
ldyzluvdis06's Avatar
Originally Posted by omc8
Where on clubgp did you find injectors? I do not see a classified section or vendors. What injectors did you get, ones from a LS4.
http://www.clubgp.com/newforum/tt.asp?appid=32
no ls4, get them from a gtp. people are always selling them.
Old Oct 26, 2012 | 02:59 PM
omc8's Avatar
Ok I see it now, dont know how I missed it. Thanks for clearing that up , how big are gtp injectors?
Old Oct 26, 2012 | 06:49 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Roughly 42# @ 58psi fuel pressure
Old Oct 27, 2012 | 08:06 PM
LilJayV10's Avatar
I was at 90% duty cycle w/ 28.8, Racetronix pump and hotwire kit on my H/C/I/E car at 430rwhp. The tuner told me it was fine. Talked to another tuner and he said I need to upgrade.
Found out my clutch was slipping and had bad valve float. I hope to be closer to 450 next time. I was thinking about 36's as I thought 42's would be too big for what I am doing.
I didn't know you could have your stock injectors upgraded.
Old Oct 29, 2012 | 12:03 PM
chevybayboy's Avatar
Originally Posted by slammedc5
WARNING- DO NoT EVEN START THE CAR WHEN uSINg LARGeR INJECTORS WITHOUT A TUNE...
Cam only and I was at 105 duty cycles at 5800 rpms. I got racetronic 42lb injectors. My tuner let me put them in real quik when the car was sitting on the dyno.
Ha I did that I took then out 2 mins later def need tune if changing injectors
Old Nov 28, 2012 | 07:59 AM
Sickness7's Avatar
I read up on these injectors a little and 1997-2003 have different injectors form the 2004+ apparently which injector am I looking for a ls1? Now I'm starting to miss my 2002 40th aniv. gtp lol.
Old Nov 28, 2012 | 02:59 PM
97-03 gtp
Old Nov 29, 2012 | 07:29 AM
Sickness7's Avatar
Thank you very much.
Old Dec 5, 2012 | 08:32 PM
blackfbird98's Avatar
if that's the case how am I supposed to make sure the cam and everything else is installed properly?
Old Dec 5, 2012 | 10:20 PM
LilJayV10's Avatar
Get some sort of mail order tune. That's what I did then had it dyno tuned.
Old Dec 5, 2012 | 11:43 PM
leave your stock injectors in at first. you have plenty of injector to idle. once you confirm it's running correctly, install the upgraded injectors and let it sit until it gets tuned.
Old Dec 7, 2012 | 07:32 PM
  #32
ss performance's Avatar
Are the stock injectors hi impedance or low impedance?
Old Dec 7, 2012 | 08:36 PM
  #33
Sir Harmony's Avatar
What's the part number for the 97-03 GTP injectors? Is it
0280155811?
Also, are these the same injectors listed as 36lb injectors, but are also 42lb injectors because they flow 42lb at 58psi and 36lb at 43psi? Or are 42lb injectors completely different?
Old Dec 7, 2012 | 10:21 PM
  #34
0280155811?
you got it.
Old Dec 7, 2012 | 11:31 PM
  #35
So why are some people saying to get 36lb injectors if they are both the same thing? Why are they differentiating between the 36 and 42lb's like they are different items (I read a few threads)
And also I imagine these are plug and play, with the exception of a tune, am I right?
Old Dec 8, 2012 | 12:54 PM
  #36
because they are actually sold as 36# injectors, but due to our higher fuel pressure they are rated at ~42.
they are plug and play as long as you have tune.
*ps, i have some for sale if you are looking.
